Redcat Monsoon Thread
#376
RE: Redcats Monsoon Thread
yes the crappy washer that goes on the outside of the bushing is no good. Take off the clutchbell, take out one of the 2 shims behind the last bearing, (so the spacer is sticking out a hair past the end of the clutchbell) then install a new washer and screw and tighten all the way down so the washer is just about touching the clutchbell. If it tightens to much take out another shim. You want the screw all the way tight but not so the clutchbell wont spin. Just did it to an avalanche today. same thing happened.
#380
I just put on the 12 tooth clutch bell and was wondering if I should have used lock tite on the screw that holds on the clutch bell and how tight should I have tightened that screw?
#382
CT
well killed the monsoon for now, shed 1 monsoon 0, wrecked the whole front left hand side never run the truggy full speed into your shed. Was goin round the corner too fast slipped and smash!!! [:@] Need to get new a-arms upper and lower, front drive shaft, and the bellcrank will post some pictures of the damage next week when i got time. (clermont sent you a pm please respond) lol
#383
Hey, I guess I could back Track and Read some old post and get a answer but this may be quicker... the Monsoon out of the box.. Is it 10T Clutchbell?? Aluminum Pipe or a Real Tuned Pipe?? Grease or Silicone in Diffs>>??
#385
ORIGINAL: Abileneminimoto
1) 10 tooth,,,,You will want the 12 tooth to Race.
2)Aluminum Pipe (s'posed to be tuned....LOL).....Upgrade it for the Track....
3) Silicone in the diffs.....
#390
CT
[link]http://www.hobbypeople.net/gallery/147131.asp[/link] theres the link for the HT pipe by SH its an amazing pipe and was a awesome hop up that did a ton for this truggy.
#391
my motor has lost pinch for the second time, temps at hottest point were 285 usually run about 245. just had motor re-pinched by someone at local track and have been throuth 5 tanks to do second break in and temps never went above 240 and have totally lost pinch again on my sh 28 p3. could a bad or dirty one way bearing do this? would a bad or dirty one way bearing cause any loss of power?
#392
FL
Are you losing your pinch when you check it all warmed up? If so the SH.28 will lose alot of pinch when warm. After it cools down it should be ok.
#393
PINCH IS GONE EVEN WHEN NO USE FOR DAYS, HOURS, OR ANYTIME. I HAVE ANOTHER SH28 WHICH IS ABOUT 3 MONTHS OLD IN MY HURRICANE PRO, COMPARED TO THIS MOTOR WHICH IS ABOUT 1 MONTH OLD AND I HAVE NO ISSUES WITH MY OTHER SH28.
#395
WI
to change over to pbs you need to get upper arms, lower arms, the pbs hubs, and the balls. if you use parts from a team vtx truggy it's a direct fit. your axals and wheel nuts will fit right to gether with the vtx parts. go to highbanksrc to find the parts but make sure the parts are for the truggy and not the buggy. these are the parts i did mine with and it works great.
#396
CT
i used some trinity xxtra strong tmaxx springs on my front shocks works good you need to stretch the diameter of spring out at the ends to fit though.
#397
WA
Well after having the am antenna wire breaking and the monsoon going wide open into a wall i got all new parts in and got her fixed, now the reson for the post heres a fast cheap mod I had put all new captured caps in you know the plastic ones and after two tanks the front outter lowers broke so off to home depot next door to the track to see if i could get something to work, i ended up fining just the right thing heres a picture of them so far they are working great after ten tanks on the track there holding up great, o yea also got another reciver for my Spektrum so one am raido in the trash....lol.
#399
