tuned /aluminium pipe
TX
RE: tuned /aluminium pipe
It depends on what kind you use. If you use a torque pipe (short and fat) you expect to see performance from the low end of the engine. If you use an RPM pipe (long and Slender) you will expect to see performance from the top end of the engine
SC
Bottem end is your take off speed like 0-50%, top end will give you more speed 50-100%. Torque pipe would work best since RPM pipes are more used for onroad cars like street or drag racing. Torque pipe is used for offroad racing and w/e else you wanna do.
