engine won't idle
OH
ok i got my engine to start the batery for my glow ignitor was in backwards...lol but now i've tried adjusting the throttle trim and idle screw but i can't it to idle and the carb is about 1mm open please help
Open the carb until it idles but not so high to where it starts to creep forward. As for the linkage you just have to adjust it back to where it stops when you press the brake on the controller. You can just roll teh truck and hit the brake and do small adjustments at a time. Then when you get that adjusted you pull open full throttle and look down the carb to make sure the carb opens all teh way.
OH
ok fixed the idle problem but now when i press the throttle and then relsease it on the controller it doesn'tgo back to idle it stays in throttle (the throttle is sticking)
OH
i think i need to do something else i will take a pic of what i think i need to adjust on a min and post to show u what i think needs to be adjusted
OH
i don't know y my truck looks so dirty only been run 2 times and never in dirt o well i circled wat i think i need to adjust
/Users/student/Desktop/HPIM0349.JPG
