quick question
The spring goes into the groove on the outside center of the shoes. The spring will attatch with itslef end to end. Just put the spring together, put shoes together then slide spring over the shoes till it rests in the groove and then install shoes with spring together.
when you put the spring together, make sure you twist the ends in opposite directions before you hook them together so the force of them going back together will keep them together. Do you guys think i used the word together enough?
