help sticy throttle on tornado bb
OH
ok i tuned my tornado and change the throttle servo and the spring and throttle linkage. When i give the car throttle and then let go but don't give the car brakes it will keep going at around half throttle from when i give it full throttle and then i have to give it full brake to stop itfrom sticking then the engine dies please help thank you.
Did you center the servo with your remote, I had my buggy do that once. Make sure your servo is returning to idle position when you release the trigger.
OH
on my remote the throttle is turned over all the way to let it id;e should i center it in the middle at idle to get it to re turn to idle after
You need to center your servo dead center with your remote.....put the knob on your remote dead center. Remove the linkage horn from the servo then turn on your remote then the car. That will center your servo. Then make adjustments from there. You should never have your knob on the remote turned all the way to one side.....sounds like thats your problem....
Wolv.
Wolv.
OH
ok centered it out and now doesn't really stuck and i got lucky today when i was running in the street i found a part i lost s month ago amd its not broken so i have a back up [sm=biggrin.gif]
also my fuel looks really dirty once i put in thegas tank and there is no rack in the tank but there is fuel by the fuel rank on the chassis and all the dirty fuel is going to the exhaust what should i do it it a bad seal?
