Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Few Questions
Old 12-16-2007 | 03:30 PM
Default Few Questions
Hi guys i just wanted to get your opinion on something, using most of the forum i was actually able to get my volcano stx up and running, Its pretty cold here maybe 35, now that i have the idle set, when i try to take off and get it mid speed to high speed, the car shuts off, and on the pinch test no matter which way i go lean or rich i cant get to engine to only rev a little it doesnt rev at all. Once i got the engine running pretty decent on the low speed and then when you would go into high speed it would die, ive been trying to figure this out for quite some time and these forums have been great help, on alotta things. Now in my situation i cant get it right, it will idle fine, just when i go to drive it outta of low speed range it kills itself.. Any ideas would help tremendously, im trying not to get frustrated with this thing.
Old 12-16-2007 | 03:32 PM
Default RE: Few Questions
it seems either way i go leaner or richer doesnt help... Hmmm the anxiousness to get out there and drive..
Old 12-16-2007 | 03:33 PM
webdr's Avatar
Its too lean. If it takes off well and then just dies, its lean, you need to fatten the needle up, especially in 35 degree weather which is VERY dense air not helping the problem. Richen the high speed, dont even worry about the low speed or the pinch test, once you get it so it will not die when it starts going fast, then bring it in and do the pinch test and get it so it cuts off in about 2 seconds.
remember to turn the needle in 1/8th degree increments or LESS. A little turn goes along way with a vertex small block.
Im on my fourth Redcat with the Vertex mill and everyone of them acted that way.
Old 12-16-2007 | 06:28 PM
Thanks ill definitely try that and let you know, hope im in the win. Thanks alot man
