Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Redcat Racing Support
 Redcat Brushless System Help (is it cogging?) >
Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Old 12-26-2007 | 04:53 PM
Default Redcat Brushless System Help (is it cogging?)
With no load on the motor, not even a pinion gear, it accelarates very slow and is glitchy and jerkey. Also, the motor connectors get hot. What can I do? Any help?
Thank you very much
- Pede_Kid
Old 12-26-2007 | 07:44 PM
cartronicshn's Avatar
Default RE: Redcat Brushless System Help (is it cogging?)
First, how many cells are you running? are they fully charged? what connectors are you using(loose connections or damaged connectors will create resistance)? also i wouldn't recomend freewheeling the motor as it may lead to internal damage as the motor may outrev itself.
Old 12-26-2007 | 08:24 PM
6 cells (Tenergy 4200mAh). They are fully charged and it is more of a stuttering than a cogging. I even tried it in a car to see what would happen and..............same thing.
Old 12-26-2007 | 08:31 PM
Hmm.. i do get an initial cogging on my rusty, but it is only on start up, i assumed it was because of gearing and the 3300kv motor but after the start up mine pulls like crazy
Old 12-26-2007 | 08:52 PM
What do you mean by start up? And also, the motor connectors get hot.
Old 12-27-2007 | 02:04 AM
If the connectors are not good ones they will get hot. Too much resistance. Invest in some deans connectors and it will make life easier.
Old 12-27-2007 | 07:32 AM
I already did. It's the motor connectors that get hot.
Old 12-27-2007 | 09:48 AM
Redcat Nick's Avatar
Did you solder them together properly to make sure that they have good connection
Old 12-27-2007 | 11:30 AM
ORIGINAL: pede_kid
Thank you very much
- Pede_Kid
to me it sounds like a bad motor. i ate the cost of a feigao doing the same thing. i thought i was smart so i popped the motor open to look for an issure and it turns out the rotor was unballanced which whipped the bearings and scored some of the windings inside. then when i reported this to the seller, they said if i opened the motor there is no warrenty. i was so mad since i only had the motor for 1 day, and only drove the car about 50 feet.
Old 12-27-2007 | 01:05 PM
I guess most of you guys dont know how to break in an electric motor. Yes they must be broken in. I have run electric for almost 15yrs and learned along time ago for best performance and longevity that electrics need to be broken in. Its the worst thing to do is to just add a battery and go running.
Old 12-27-2007 | 08:54 PM
The solder connection is fine.
Old 12-28-2007 | 02:41 PM
ORIGINAL: twomanytoys
And how do you "break in" a brushless motor setup?
Old 12-28-2007 | 02:46 PM
Yea, only brushed motors have to be broken in.
