Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Compression Question
Old 02-23-2008 | 01:41 AM
nitronoob08's Avatar
Default Compression Question
ok just wonder how you check your nitros compession to see if its good or bad any tips would be kewl
Old 02-23-2008 | 01:55 AM
Cam_132's Avatar
Default RE: Compression Question
when you turn the engine over you should get a substational amount of compretion but if you get compresion at all (mid) you are ok if your engine goes Pluck Pluck Pluck you are fine but if you engine goes Woosh woosh woosh your engine is screwed...
Old 02-23-2008 | 02:07 AM
lol it goes pluck pluck pluck
Old 02-23-2008 | 02:51 AM
Cam_132's Avatar
then your engine is fine... and how old is it?
Old 02-23-2008 | 09:35 AM
Also if you pick up on the pull start the car should come with it. If the pull start comes out and car sits on ground its weak.
Old 02-23-2008 | 09:56 AM
the best way to check is when its warm, most engines have compression when they are cold but when warm will loose some, if you can pull the starter real easy when warm, its shot.
Old 02-23-2008 | 11:56 AM
Cam_132's Avatar
ya that is the other way... to check it when warm... and the other way is good to becouse you can check for scraches and dabree and rust...(make sure you do this when the engine is cold.) take your engine head off and pull out the sleeve and open the crank case by removeing the pullstart and makesure the spring does not come out (becouse it is a b**** to get back in) take the back plate off and check for rust then pull the sleeve out then slip the piston off of the crank and once it is out put the piston in the sleeve and and move it around if it is tight it is good and try to push the piston out the top of the sleeve if it comes out easily then your engine is screwed... but if it does not (dont force it just see if it stoppes) then your engine is good...
Watch this for engine dissambily.
http://ca.youtube.com/watch?v=dP6l3Pmt0Bw
watch this for engine reassimbily
http://ca.youtube.com/watch?v=yZpItk...eature=related
so there you go
