The Cost of a Conversion
TN
This is a conversion from a buggy to a Tsunami
Here is a list of everything I got to upgrade and convert my buggy to a Tsunami, I sure do wish I knew what to get from the get go or I wouldn't of had to convert it over, Most of these parts are from RedCat Racing, Clermont, and Allaboutfunhobbies except the servo's, Tires, rims, transmitter and receiver. Just to let though's know who want to convert what to look forward to and what is needed.
1 x 02101 Steering Liner 12 pcs .................................................. .................$3.05
1 x 02089 TPE 3*15 FH Screw .................................................. ....................$1.40
1 x 02103 Waistband .................................................. .................................$1.00
1 x 02077 Flower Cover of Bumper .................................................. .............$3.05
1 x 02027 Heat Resistant Exhaust Coupler........................................... .......... $1.95
1 x RCE10423 13 Tooth Vented Racing Clutch Bell .........................................$15.95
1 x 05126 Single Speed Transmission (Center Gear Box) ...............................$15.00
1 x 02055 Nylon Locknut M4 .................................................. ......................$1.90
1 x 08021 Shockproof Ball Head.............................................. .................... $4.95
1 x 02005 Rear Bumper .................................................. ............................$2.25
1 x 02048 White Teflon Clutch Shoes............................................. ................$4.75
1 x 08054 Aluminum Shock Tower .................................................. ..............$13.95
1 x 02016 Drive Cup B................................................. ............................... $4.95
1 x 08031 Rear Shock Mount Support........................................... ................ $2.50
1 x 08030 Front Shock Mount Support .................................................. ........$2.50
1 x 08007 Front Mount of Car Body .................................................. ............$2.30
2 x 08012 Shock Proof Plank .................................................. .....................$4.60
2 x 06267 Hex Nut and One Way Bearing for Spur Gear 06032....................... $13.50
1 x 02103 Waistband .................................................. ................................$1.00
1 x 02128P Engine Mount, Purple Aluminum.......................................... ........ $8.75
1 x 02125 Battery Holder for Aluminum Upper Plate ......................................$0.80
1 x INTC22473P High Flow Air Filter Type III 15-28....................................... $17.99
1 x 02026 Exhaust Pipe .................................................. ............................$4.95
1 x 02027 Heat Resistant Exhaust Coupler .................................................. .$1.95
1 x 06001 Chassis .................................................. ...................................$15.50
1 x 02014 Front Hub Carrier .................................................. .....................$4.99
1 x 02015 C-Hub .................................................. .....................................$4.99
1 x 02022 Front Arm Holder *1PCS .................................................. ...........$0.90
1 x 02037 E-clip 2.5*12PCS .................................................. ......................$1.99
1 x 02051 Differential Housing .................................................. ..................$3.00
1 x 06048 Aluminum Linkages 2pcs .................................................. ...........$23.20
1 x 08005 Front lower arm *2pcs .................................................. ..............$1.20
1 x 08020 Front Lower Suspension Arm Hinge Pin ........................................$3.20
2 x 08029 Dogbones 90mm qty 2 .................................................. .............$9.98
2 x 08041 Aluminum Shock for Volcano .................................................. ....$25.95
1 x 41102 1/10 Truggy Body.............................................. ........................ $7.50
1 x 08019 Rear lowe arm round pin B*2 .................................................. ...$3.05
1 x 02014 Steering Arm *1Set............................................. ...................... $3.99
1 x 02013 Rear Axes Holder 4*4-2PCS.............................................. .... .....$3.99
1 x 02051 Gear Box .................................................. ................................$7.00
1 x 02021 Rear Arm Holder *1PCS............................................. ................ $2.99
1 x 08006 Rear lower arm .................................................. .......................$3.75
1 x 02063 Rear lower arm round pin A *2PCS .............................................$3.00
1 x 02299 exhaust gasket............................................ ............................. $2.99
1 x 02034 Universal Joint A *2PCS & Screw *2PCS..................................... $2.99
1 x 02016 Universal Joint B *2PCS & Screw *2PCS .....................................$3.49
1 x 02032 Universal Joint C *2PCS .................................................. ..........$3.10
1 x 02057 Mast 4PCS $2.10 .................................................. ....................$2.10
1 x 1618 Backplate for rotostart 16/18 .................................................. ....$14.99
1 x 1/10 scale Polished aluminum tuned pipe nitro RC ................................$19.99
1 x New 1400 mah 5 cell Hump Receiver Battery Pack............................... $17.95
2 x HPI Yokohama Geolandar 2.2 Tires Rustler RC10GT Rush..................... $28.46
1 x Purple Anodized Fuel Filter for Nitro Cars .............................................$7.80
2 x MG995 Metal Gear High Speed & Torque Digi Servo............................. $20.00
1 x Ofna 5-Cell 6V Hump Pack w/Charger Savage 25 X T-Maxx................. $23.86
2 x HPI Pro-Line Moab 2.2 Tire Fr/R .................................................. .......$30.58
2 x 2.2 Mudrock ch beadlock chrome rim for crawler tlt F350 .....................$44.80
1 x Himoto upgrade upper radio chassis plate........................................... $34.95
1 x Futaba 2PL 2ch RC system with one R142JE receiver, 75MHz................ $35.00
Shipping .................................................. .............................................$23.0 0
Shipping .................................................. .............................................$6.75
Shipping.......................................... .................................................. ... $6.75
.................................................. ..................................................Total of $594.71
DUDe thats lie 2 Avalanches or 1 monsoon and 1 avalanche or 1 Hurricane and 1 avalanche or 1 hurricane and 1 monsoon or like 3 tsunamis, 2 Ultrawides.
ORIGINAL: Macanan
It's easier to get it a little at a time then to come up with the whole thing at once.
The Cost alone is only HALF the story here. Its true that he could have purchased 2 cars for that price. But THINK of all the hands on experience he got Solving all the problems that went along with Doing this Mod! Great training. Cant put a price tag on That. He is now equipped to solve just about any problem he will ever encounter on a Nitro based RC.
Mac...If you were a Newb when you started.....you're a Veteran Now.
Congratulations.....
TN
Thanks Red and yes I was a newbie in this, and one thing about me, I'm not the type of person that will get many different things, I like challenges, and when I believe in a product I will stick with that Product, Yes I had a few snits about the shipping issue's, but as we all can see I paid good money for ONE REDCAT Tsunami, I now call my $600.00 car, which what I would really love to get is the AVALANCHE XP which I will never be able to afford, because I cant come up with that kind of money in one whack, so I built me something I can be proud of, something I can say HEY I did this, I built this from the ground up.
CA
ORIGINAL: Macanan
ORIGINAL: Macanan
1 x 02089 TPE 3*15 FH Screw .................................................. .................$1.40
1 x 02077 Flower Cover of Bumper .................................................. ...........$3.05
1 x 02027 Heat Resistant Exhaust Coupler........................................... ........ $1.95
1 x RCE10423 13 Tooth Vented Racing Clutch Bell ....................................$15.95
1 x 05126 Single Speed Transmission (Center Gear Box) .............................$15.00
1 x 02055 Nylon Locknut M4 .................................................. ....................$1.90
1 x 08021 Shockproof Ball Head.............................................. ................... $4.95
1 x 02005 Rear Bumper .................................................. .............................$2.25
1 x 02048 White Teflon Clutch Shoes............................................. .............. $4.75
1 x 08054 Aluminum Shock Tower .................................................. ............$13.95
1 x 08031 Rear Shock Mount Support........................................... .............. $2.50
1 x 08030 Front Shock Mount Support .................................................. ......$2.50
1 x 08007 Front Mount of Car Body .................................................. ..........$2.30
2 x 06267 Hex Nut and One Way Bearing for Spur Gear 06032................... $13.50
1 x 02128P Engine Mount, Purple Aluminum.......................................... ...... $8.75
1 x 02125 Battery Holder for Aluminum Upper Plate ....................................$0.80
1 x INTC22473P High Flow Air Filter Type III 15-28................................. $17.99
1 x 02026 Exhaust Pipe .................................................. .............................$4.95
1 x 06001 Chassis .................................................. .....................................$15.50
1 x 02022 Front Arm Holder *1PCS .................................................. ........$0.90
1 x 02037 E-clip 2.5*12PCS .................................................. ...................$1.99
1 x 06048 Aluminum Linkages 2pcs .................................................. .........$23.20
1 x 08005 Front lower arm *2pcs .................................................. ............$1.20
1 x 08020 Front Lower Suspension Arm Hinge Pin ....................................$3.20
2 x 08029 Dogbones 90mm qty 2 .................................................. ...........$9.98
2 x 08041 Aluminum Shock for Volcano .................................................. .$25.95
1 x 41102 1/10 Truggy Body.............................................. ...................... $7.50
1 x 08019 Rear lowe arm round pin B*2 .................................................. $3.05
1 x 02014 Steering Arm *1Set............................................. .................... $3.99
1 x 02013 Rear Axes Holder 4*4-2PCS.............................................. .... $3.99
1 x 02051 Gear Box .................................................. ..............................$7.00
1 x 02021 Rear Arm Holder *1PCS............................................. ........... $2.99
1 x 08006 Rear lower arm .................................................. .....................$3.75
1 x 02063 Rear lower arm round pin A *2PCS ........................................$3.00
1 x 02034 Universal Joint A *2PCS & Screw *2PCS.............................. $2.99
1 x 02016 Universal Joint B *2PCS & Screw *2PCS ..............................$3.49
1 x 02032 Universal Joint C *2PCS .................................................. .......$3.10
1 x 02057 Mast 4PCS $2.10 .................................................. .................$2.10
1 x 1618 Backplate for rotostart 16/18 .................................................. ...$14.99
1 x 1/10 scale Polished aluminum tuned pipe nitro RC ...............................$19.99
1 x New 1400 mah 5 cell Hump Receiver Battery Pack............................ $17.95
2 x HPI Yokohama Geolandar 2.2 Tires Rustler RC10GT Rush................ $28.46
1 x Purple Anodized Fuel Filter for Nitro Cars ..........................................$7.80
2 x MG995 Metal Gear High Speed & Torque Digi Servo........................ $20.00
1 x Ofna 5-Cell 6V Hump Pack w/Charger Savage 25 X T-Maxx............ $23.86
2 x HPI Pro-Line Moab 2.2 Tire Fr/R .................................................. ....$30.58
2 x 2.2 Mudrock ch beadlock chrome rim for crawler tlt F350 ..................$44.80
1 x Himoto upgrade upper radio chassis plate............................................ $34.95
1 x Futaba 2PL 2ch RC system with one R142JE receiver, 75MHz.......... $35.00
Shipping .................................................. .................................................$ 23.00
Shipping .................................................. .................................................$ 6.75
Shipping.......................................... .................................................. ....... $6.75
Total of $594.71
Total of $594.71
ORIGINAL: Macanan
bro, dont think i am putting you down, far from it, its coold that you were able to convert your buggy, just a shame you had to spend so much money on doing it, just figured you could have bought a tsunami, upgraded it and had a few bucks left over. sorry if it sounded bad
you have all the bragging rights bro!!!!!!!!!. you did it the hard, probably the most rewarding way. we just bought them, you actually built one. WAY TO GO BRO!!!!!!!!!
TN
Thanks Guys.
As we all know we can only do with what we have and know what to do. This forum here Redcats has inspired me into transforming it over to a Tsunami, and as well the terrain that where I live sucks, and I needed something that would run good on rocks, red clay and hill's, and with what I had, a Tsunami was the only choice I had to convert to.
you say you dont have th e money to spend all at once. That makes sense,but if you saved up the money, used the car you had, used all the money you put into that car, you would now have the tsunami and the avalanche.
Other than that, you did a great job. I dont have the patience. I did just put a pro kit together and didn't pay someone or have a worker do it this time lol...
TN
ORIGINAL: Clermont Hobby
HOLY **** haha i read all those post and im glad i found my Volcano SV on ebay lol ... if i had to build it
i would probably not be sleeping for weeks because i would want to run it so bad haha.
i cant sleep as it is because im so impatient and excited about mine coming this week and i just paid for it on ebay about 4 days ago
and its driving me insane ... counting the days, hours, minutes and seconds till it arrives.
