fuel pressure question
anyone know of a way to hold pressure as you near the end of the tank.... way to rt the hoses or a check valve? any ider??
If your system (tank, fuel/exhaust lines, carb and engine ) is sealed tight, you should have the correct pressure in the tank, even if it is near empty.
What makes you think your pressure is low?
As far as routing hoses: I know racers like to run extra Loops of fuel line. This gives them a bit more run time and guards against fuel starvation when cornering real Hard.
an engine will run lean as the tank gets empty, if its tuned correctly your ok, if its running hot twards the end of a tank of fuel, you need to richen the hsn a little, like an 1/8. see if that helps.
ORIGINAL: ehroof
Now that I THINK about it , it makes sense.
Yeah...Ive noticed smoke in my tank to. Wondered what it was from....
