Some help with a new carb
i finally got a chance to install my new sh .18 carb on my tsunami, i got it on, set the hsn to 2.5 turns out, lsn flush with the collar, and the gap in the airfilter hole to about 1mm, primed it, no start, no gas out of the exhaust or the airfilter hole....some suggestions?
RE: Some help with a new carb
yes, sh carb + sh motor...and yes the fuel goes to the carb, no holes, it worked before the new carb, just the old carbs idle set screw was broke...ill try readjusting the lsn when i get home again...Thanks
i let the lsn out a little more, fuel comes out of the carb through the airfilter hole now...i think i my need a new glow plug or slow starter though now, as i took out the plug, put it in the starter, nothing happenned....going to the local hobby shop tomorrow to get one or the other/get my plug checked...if i need a new plug, what should i get?
you may have flooded it and got fuel in the glow plug, i have done that before and just blew some air in the glow plug and it started working again. but you should probably get some more glow plugs anyways.
any #8 plug should work
went to the hobby shop today...plug and starter are fine. we tinkered with it for a while but it is still not idling right...the hsn is at 2.5 turns out, and to get it to start, the lsn has to be at around 3.75 to 4 turns out, it can be lowered to around 3 turns out(about flush with the collar) but it wants to die and still wont stay still...it wants to drive away...the idle set can be lowered until it dies(a little bit at a time of course) and it still will not stay still.
im thinking of sending the motor and carb to redcat and having them put it on a chassis and having them tune it...cus the guy at the local hobby shop cant figure it out either....if nothing else, ill sell it and buy one from the hobby shop.....
TN
I don't know if redcat does that or not I'm not sure but I do know Allaboutfunhobbies does it.
http://allaboutfunhobbies.com/store/...p/cPath/23_111
already broken in....it was used and run, but it wont run right now..........should i pm allaboutfunhobbies and ask if they will just get it running, so they know that I dont actually need a break in?
TX
Hey you can send me either the whole car or just the engine, prefer the whole car on the small engines. It's already broken in so it sounds like it either just needs a tune up or something simple like maybe you have a hole in the fuel line or maybe a leaking fuel tank seal. Double check all your exhaust and fuel system connections make sure everything is sealed tight and none of the fuel lines are leaking. If you still can't get ti to start give me a call or pm me and I'll give you my phone number so you can call if you need to.
also check the head and make sure there is not gas leaking through the glow plugg thats what happenend to me i replaced the plug and now it runs great, mine is also an SH .18
