Cleaning brakes
ON, CANADA
Cleaning brakes
anyone have a useful way to clean brake pads. mine are all gummed up with oil and WD-40. makes it interesting to slow down sometimes.lol
RI
RE: Cleaning brakes
I've used Denatured Alc. and tried Contact Cleaner (for electronics). That seemed to work well also. The aerosol seemed to help blow the crud out.
I'm thinking of getting one of [link=http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1102]these[/link] from harbor freight and loading up som denatured alc in it. Come to think of it, I have a gallon of WD40 I've been using in a spray bottle. I may buy 2 of them.
RE: Cleaning brakes
ORIGINAL: TThib
I need me one of THOSE. Be WAY cheaper thaen that NITRO spray Ive been Buyin at the LHS.....
Maybe add a little Sparkling Water for FIZZ and some Simple Green for Cleaning Power...along with the Alchohol.......
You'd have your Very Own toxic Swill
OH
RE: Cleaning brakes
this is an old trick used on full size cars that had oil soaked brake shoes. You spray them down with brake cleaner (alcohol) and then heat them up someway like a microwave or oven. I did this on mine and it worked great. i heated mine in the microwave for 4 min after I soaked them in brake cleaner. They came out alright and stopped alot better
RI
RE: Cleaning brakes
Ok... Here's another little trick I found on the web...
Homemade nitro cleaner
You can make your nitro-car cleaner easily and affordably by mixing two parts denatured alcohol with one part Simple Green. Store the cleaner inside a pump spray bottle, and top off the brew with a capful of WD-40. Be sure to shake the bottle before every application because the solvents separate over time. One gallon of denatured alcohol and a 2-liter bottle of Simple Green will make enough nitro cleaner to last months.
Then load it in the refillable aerosol bottle...
RE: Cleaning brakes
When cleaning my brake pads - I take a scotch brite pad, and tear the "scuffing" part off. I then spray a little brake cleaner/electric motorspray/nitrocleaner on it, and rub the brake pad on it untill its clean. It's not as bad as sandpaper and still does a good job.
