Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
please help
Old 03-16-2008 | 08:22 AM
Default please help
i can't seem to get my tornado shockwave to run right any more i had played with the idle screws after i broke a c hub ,
and now that the c hub is fixed i have been tryin to get the carb back to original settings i get it start and idle for 10 seconds then dies if yougive it throttle please help
Old 03-16-2008 | 09:56 AM
AllAboutFunHobbies's Avatar
Default RE: please help
It's either too rich on the high needle or too lean. When you give it throttle does it spit out alot of smoke or not much? Also how many turns out from seat do you have the highspeed needle? Your lowspeed should be flush with the collar.
Old 03-16-2008 | 10:51 AM
i just set the low speed to flush and the high speed is about 2 and three quarters out
Old 03-16-2008 | 10:53 AM
were is ur idle screw set????????????
Old 03-16-2008 | 11:10 AM
about 1 mm
Old 03-16-2008 | 11:19 AM
should run..
Old 03-16-2008 | 11:22 AM
i'm gonna give it a shot soon
I had a similar problem with my BB. What I did was turned all 3 screws in all the way, came out 2 full turns with them, and that got it to stay running. Then I adjusted from there. A minimal turn here and there and it was running good.
Old 03-16-2008 | 11:51 AM
rclynx's Avatar
Glow Plug [sm=confused.gif]
Old 03-16-2008 | 12:42 PM
Macanan's Avatar
ORIGINAL: Cainman6969
Go 3 to 3 and a half turns out on your High speed needle then go 2 and a half to 2 3/4 turn on your low speed needle then have the opening to the carb like how the picture shows
If you try all the above from everyone surely something has to work.
Old 03-16-2008 | 02:59 PM
set the needles to 2 1/2 out on the high, flush with the low, 1-2mm opening on the carb and if that doesnt get you going decent, put in a new plug, os a3 or any other hot plug
