Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
steering servoWh
Old 03-23-2008 | 10:17 AM
Default steering servoWh
I think my steering servo is going bad. When I turn the car on it does the normal quick twitch. Then when I turn the wheels with the Transmitter it starts twitching really bad. If I try to hold it turning in either direction it is like it is struggling to hold it. Could this be my servo going bad? I have all new batteries so I know that isn't the issue. Can I use one of the servos from my tornado or will that be too small? and sorry for the Wh in the topic part. hope that didn't confuse anyone.
Old 03-23-2008 | 10:26 AM
Default RE: steering servoWh
you could try to take it apart. if you want take pics of it as you do it there is a centering gear in there and a real small gear on the motor my bros was doing that and it was the gear on the motor slippin super glue it on but dont go crasy with it DONT GET IT IN THE MOTOR. make sure the centering gear is where it stopps spinning you will understand when you get it apart. I cant explan real well.... sorry hope you get it fix man
Old 03-23-2008 | 10:38 AM
i will see what I can do. Thanks bro
Old 03-23-2008 | 11:07 AM
mine did the same thing on my volcano and it turned out that the antennae wire wasn't making a good connection to the circuit board. i soldered it and it works fine now.
Old 03-23-2008 | 12:45 PM
Redharris's Avatar
Yeah....and check the 3 servo cables are soldered securely inside the Servo case. They break or come Loose sometimes....
Old 03-23-2008 | 03:22 PM
ya that dosent sound like a bad servo. have you been driving in water???. thats what happend to mmy freinds tornado when he was driving in the rain.
Old 03-23-2008 | 09:03 PM
ok got it figured out. I forgot I switched out the battery pack and I had fairly old batteries in the pack. oops. Put new batteries in and it was fine. Thanks for everyones input though.
