Pullstart ?
My pull start on my xp works great... when it works. Lately when i pull the cord it catches 1 or 2 times. Never had a prob. before and is there an easy fix to this?
One way bearing, my does the same thing, the cold causes it not to function correctly. It works fine when the motor is warm! I believe ehroof has a bandaid fix somewhere in one of these threads!
take off the pull start, take off the backplate and the one way bearing,clean with carb cleaner and put it back in, will work for a while or for good, depends on the fuel your using, traxxas top fuel and a few others have alot of oil and cause the one way bearing to slip.
ORIGINAL: TThib
Getting rid of the pull start and installing a roto won't solve his one way bearing problem, it stays put.
I guess I've just personally had some issues, well not some, actually just one big one, with the stock pullstart, I upgraded to roto, but I would imagine their are better pull starts out there if you like them.
Yes... The one way bearing is on the inside of the backplate. 4 screws take off the pullstarter, 4 more take off the backplate. You don't have to remove the backplate to put a rotostart on.
Ah Yes, I was playing ice hockey a few months ago and took a slapshot from the point. A fraction of a second before I hit the puck, I got hit from the side causing my stick to hit the ice early. Apparently the torque was enough to do a number on my rotator cuff. Rehab for now, I want to avoid the surgery.
ORIGINAL: RoadBurner
Is this correct, I never seen a roto start or a back plate for them, I just bought one from Clermont though! I hope he has lightning fast shipping!
ORIGINAL: TThib
within 4 days from the day you ordered it...I get my stuff in ks in 3 days
ORIGINAL: firebird78
hopefully u got the starter wand with that roto start...lol...if not i'm sure u can rig somethin up to turn her over.
TN
So I had a problem with the pull-start I got from Redcat. It was for my Volcan SV/ VX.18 the pull-start had the right bolt pattern but the cut out for the OW was way too small! So I called Redcat and they are supper cool! He said he had not seen this but would look into it. They sent me a new OW and a new pull-start and now that i have both of them here I see that the 1st pull-start they sent did have too small of a cut out for the OW and as far as i can tell the two pull-starts are the same in every other way so i hope someone from Redcat will see this and sort out the problem? I would say that there manufacturer has made some off a bad mold? and this may be a hard fix for them because neither pull-start had a part # on it? Well I hope no-one else gets the wrong one. I'm off to do some bashing!!!!!!
