Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
diff question
Old 04-05-2008 | 12:00 AM
Default diff question
i have a volcano sv and the diff grease i changed out to plain old valvoline extreme pressure grease i had for my grease gun will that wreck anything on the truck? or just give better traction?
Old 04-05-2008 | 01:04 AM
rc rock's Avatar
Default RE: diff question
it should be fine, not sure if youre going to have better traction....
why not diff oil?
Old 04-05-2008 | 01:13 AM
i used grease because it was there and i din't have any diff oil,lol but i thought it couldn't be any worse than already is. the grease seems to almost have a locker effect on the rear diff. both tires spin under power not just one
Old 04-05-2008 | 09:54 AM
you will have better traction with thicker oil/grease because the 2 wheels will grab better, thicker oil/grease locks the diff up more
Old 04-05-2008 | 10:05 PM
Boxhead from MN's Avatar
Stupid question but, how do you keep the grease in the rear diff?[sm=red_smile.gif] Tore my Volcano apart tonight and
saw the bottom is open. Also, was talking to a friend of mine and suggested using anti-seize. Would this
work?
Chris
p.s. Kinda quiet in the Redcat forum tonight.
Old 04-05-2008 | 10:25 PM
AllAboutFunHobbies's Avatar
it's nto really oil in those it's more like different weights of grease. The lighter the looser, i guess you could say, the gears, the thicker the tighter and the more of a posi locking effect it has. So I would think that using anti seave(which tends to be pretty thick) would have a locking effect. Also if I'm not mistaken the chassis doesn't have a hole in the bottom where the diff sits so the grease stays in the diff housing.
Old 04-05-2008 | 10:26 PM
7M
ORIGINAL: Boxhead from MN
work?
Chris
Only the differential carrier is filled with grease. The pinion itself is just lubricated with a thin layer of grease.
Old 04-05-2008 | 10:27 PM
Macanan's Avatar
work?
Chris
Box head what car you have ?
Old 04-05-2008 | 10:28 PM
LOl, good point, forgot about that, lol.
Old 04-05-2008 | 10:43 PM
Volcano SV. Does the rear come apart? If so, how.
Old 04-05-2008 | 10:47 PM
Macanan's Avatar
The four screws under it will take it off then you look at the screws on the case to take it apart, after that look at this picture
