MONSOON WHEELS
does anyone know a good set of replacement wheels for the monsoon? I just got one and was on the 4th tank of break in when one broke in the center and the wheel rolled away took it in pulled the other ones off and two others are all cracked and about ready to break. looking for something considerably stronger to fit the stock tires.
Dennis do you have them? also I need
front post brace part # 88030
88015
81028 if you have those parts I would like to buy them and the wheels
thanks
88015
thanks
FL
Aren't the 40 series the real wide ones like what come on a Muggy? If so why would you put those on there. Get a set of Proline LPR's half inch offset with some hub extensions and it will handle like it is on rails. You need the hub extensions just to make it as wide as it was with the stock wheels because the stock ones are I think a 1" offset. If you do not do that your monsoon will be narrower than before and not handle as good because you CG will be higher.
I've been using offna 17mm hex buggy dish wheels and they work just fine and you can get them just about anywhere. Almost identical in size to the stockers.
All the stock wheels for this [link=http://www.xtm-dealer.com/XTM%20Mammoth%20Tires.html]40 series 17mm hex Wheels[/link] fit these [link=http://www.xtm-dealer.com/40%20tire%20series.html]40 series Tires[/link] and a lot more if you ask [:-]
