how to remove fuel tank on tornado bb?
CT
there is a crack in my fuel tank on my tornado bb and i cant figure out how to get the fuel tank out. i cant even unscrew the one screw that i can get to cause its so tight its unbelievable. i was wondering what i chould take off to get to the other screw. i took off the exhaust and still couldnt reach any kind of tool in there to get to it. im not sure what i should do.
the best and easiest way to do it is to remove the entire upper plate. sounds like way more work than it actually is. it is only about 8 screws or so. once it is off you can easily access the tank.
CT
i tried to remove the upper plate and there is a bold holding on the servo arm i believe and i cant get it out it just spins and spins i took the screw out holding it from the bottom of the chasis and it still wont come out it just turns and turns any suggestions
