Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
volcano sv idle problem
Old 06-04-2008 | 02:41 AM
Default volcano sv idle problem
i have a volcano sv when i start it, it idles high just so that the wheels are not spinning, but after i go for a drive and bring it in, the revs on idle go down and it stalls after about ten seconds can anyone help me im not sure if it is something to do with the lowspeed adjusment because the opening when brakes are applied is about 1 to 1.5 mm
Old 06-04-2008 | 12:59 PM
nubzorz's Avatar
Default RE: volcano sv idle problem
well you can try to lean the lsn a little bit and i would open the carb hole up to about 2mm and see what happens lean the hsn slightly also
Old 06-04-2008 | 04:54 PM
Cam_132's Avatar
Lean or richen the mix till it stays running for more than 10sec... i have had the same problem too that my tornado would not stay running unless the idle was high... so just play with it just turn it 1/16 to 1/8th of a turn on the low speed needle till it stays running.
