High and low speed needle settings
Hi all
I hope someone can help me here. I have the Redcat Earthquake and was wondering what the high and low speed needle settings approximately are when the car is properly run-in? My car is run-in but my high speed needle setting is about 3 turns from out and my low speed setting is about 4 turns from out, does this sound correct? I can't get the car to run at any other setting besides these so i'm presuming that this is the correct settings for the motor, but then i read that normal settings for car engines is about 1 - 2 turns for the high speed needle and about 1 turn for the low speed needle. Are the engines on these cars different from other engines?
I have done the pinch test for the low end and it seems correct. Also the temperature of the car is fine. One thing to note is that i did find an air leak between the carb and the motor but i fixed that with high temperature gasket sealant.
So basically i'm interested to know what your settings are when you have completed the break in procedure?
Thanx for the help!
Thanx for the help!
try 2 1/2 turns from all in on the high and 3 1/2 turns from all in on the low...also make sure you idle is set at 1 mm open by looking down into the carb (you need your radio system turned on to do this)...this should get you running
