Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Breakin Help
Old 07-03-2008 | 04:57 PM
Default Breakin Help
How much smoke should i be seeing during break in. Ive ran the 1st tank through and I think Ive got it set but im not sure. Ive got sum fuel coming from the exhaust.
Old 07-03-2008 | 05:45 PM
Default RE: Breakin Help
you prolly have the oil coming from the exhaust....which engine are you beaking in?...if its a .18 .16 put your high at 2 1/2 out you low flush with the collar....if its a .21 or .28 2 1/2 out on the high speed needle and 3 1/2 out on the low...basically the .16 and .18 collar is approx 3 1/2 out...if you go flush with the collar on a .21 or .28 your to far out...here is a pic to help u out
Old 07-03-2008 | 06:26 PM
well thanks ive ran 2 more tanks through it before the throttle servo freaked out and LOL it bit me *** i dont know what happend was crusing at half throttle and wam its freaking out wide open craziness
Old 07-03-2008 | 06:54 PM
what model do you have???..which radio?? what kinda batteries you using in the car?? are you running a failsafe??/
Old 07-03-2008 | 07:35 PM
The servo locked up. Ive got the Tornado S-30. Which radio by the controller or the servo? The controller is an am frequecny and the servo was hispeed 3003 or sumthin close to that. Failsafe??? No killswitch yet gona get one now LOL
Old 07-03-2008 | 07:43 PM
sounds like you had low batteries...I suggest using reciever hump packs...less likely to jar the battery loose then running AA's...a failsafe dosnt kill then engine...it locks up your brakes when either you run out of range or you have low battery....it however does not activate your brakes if you loose battery power to the reciever (battery jumps out of the holder)....if you are using AA's in the reciever I would wrap a rubber band around them
Old 07-03-2008 | 08:16 PM
i just bought new batteries 2 day i think i might of got a rock stuck in the servo area cuz the servo was lockd up i changed batteries and no luck i took the servo apart to find the gears lockd tight even with power on. All it would do was hummmmmmmmmmmmm. I also wrapped the batteries with a rubber band when i first put them in. My father in law had the same thing happen to him after i had to call him to tell him what happend
Old 07-03-2008 | 08:26 PM
you also might check to amke sure your crystals are in tight....but sound like you need a new servo.. I do believe redcat has a 30 day warrenty on electronics...so you might wanna email Darin and see about getting a new servo
