Volcano EPX PRO higest battery voltage?
WI
Whats the higgest voltage battery you could put in the Volcano EPX PRO brushless before the esc or something cuts out. I heared from some people it could go up to 12volts while others said only 8.4volts. Whats the truth???
NJ
RE: Volcano EPX PRO higest battery voltage?
I have the very same esc and motor that comes with the EPX PRO's. I've used it with 12 cell NICD's however when I used some higher quality cells (12), it started cutting out.........10 of the same cells cut out again
WI
Are you sure it would be able to hande this 7 cell http://www.spcracing.com/index.php?productID=31 ????
