Volcano turning problem
I put on aluminum upper and lower arms. Now the dang thing wont turn very sharp i've tried all the adjustments and nothing would a better servo help and if so what one. thanx
RE: Volcano turning problem
Just have to ask. Did you check out the servo saver? Its the thing with the knurled nut at the topp, next linkage out from your servo. Does it " come apart" when you steer? Does it turn full lock when you hold the front wheels off the ground? If so, screw down that steel knurl on the top. Lots of folks miss this.
ALSO.. Just a thought, not to insult your intelligence or anything, but are the batteries fully charged in the receiver pack? Sometimes you can buy dead batteries from the store.. It does happen. I personally recommend teh NiMH rechargables you can get from yer local store. You charge them, they last, and have over 2000mAH current. Nice deal..
Enjoy your truck! They built fer fun!
