volcano sv dogbones
RE: volcano sv dogbones
How much longer? Have you done mods, or is it just falling out occasionally because it's a bit border-line? You can stick a 1/8" length of fuel tube in each cup in order to center the dogbone and stop it from moving about too much if that's the case.
The cups can probably be moved a small amount too - I think they're keyed onto the shafts with a flat on the shaft, not a hole - meaning they can slide a long a small amount and the set screw can still clamp onto the shaft OK
