Non-servo saver steering post?
Question for Redcat or anyone who might have info.
I've replaced my stock Monsoon steering servo with a JR Z9100T (300oz @ 4.8v). The problem is the servo is just too beefy for the stock steering column with servo saver. i.e I have to tighten the adjustable nut pretty much fully closed to get full end-to-end steering at low speeds. Otherwise the servo saver splits and I get almost no steering angle at a stop/slow speed. Kind of defeats the purpose of a servo saver if I have to fully lock it to get good steering response. Is there a solid steering column part available I could use and switch to a horn saver where I'd have better control over when it kicks in (by using a stronger clip) but still have save functionality?
RE: Non-servo saver steering post?
Thanks for the reply but no, the EPA are set correctly. Up on blocks the steering is fine and unhooking the steering servo turnbuckle the side-side steering action is fluid but not sloppy so it's not a binding issue. I think it's probably just a weak spring in the servo saver at this point.
CA
If its a plastic servo saver throw it in the garbage and get an aluminum one don't bother to try and adjust it any more [:-]
ORIGINAL: rclynx
