landslide suspension
I've had my landslide apart a couple of times and I've noticed that the little white bushings that hold the suspension arm pins can go in 2 ways.Youwill get a little more toe-in on the back suspension if you place the holes to the outside.Is there a proper way to install them?
RE: landslide suspension
Either way is fine, you can use toe-in to tune the way your car drives. More toe-in will make your car handle better in turns, while less toe out is better for straight line speed.
