Rotary vs slide
Rotary vs slide
So let me know if I'm wrong. The volcano S30 has the sh eng with the rotary carb, but the T2 has the same eng but with a slide carb whats the differents? I think the slide carb must be better but in what way? How much more performance do you get from the slide carb? Can you put it on a S30?
MN
RE: Rotary vs slide
yes the slide carbs oben faster giving you better acceleration, but i dont think the slide carb will work on the s30 because of where the throttle/brake servo is mounted
AZ
RE: Rotary vs slide
you can make it work, just move where the bracket that moves the carb towards the front. I dont see it being much different though, because it will open what like half a second faster? plus if you get a faster servo it will be just the same right?
RE: Rotary vs slide
popular opinion is that one gives finer control in the middle of the travel and so is good for off-road, and one give finer control at the top of travel (i.e. WOT) and is better suited to on-road. Frankly I don't see why that would be the case, so ultimately it comes down to layout of the vehicle - if the servo is in-line with the engine then you'd use a rotary carb, and if the servo is beside the engine you'd use a slide carb.
IN
RE: Rotary vs slide
i do know that in the dirt bike 2 stroke world, flat slide carbs give faster. crisper throttle response.
It has to do wit the fact that with a flat slide carb, you are esentially sliding a flat plate up & down (very simple movements) where as with a rotary carb you are rotating a "drum" which takes more work.
but we're talking micro-seconds of difference here, but that amounts to crisper throttle response.
much like fuel injection vs. a carburetor.
but i don't really think that you'd see a huge difference by adding a flat slide carb.
it won't be like going from a rotary carb to a flat slide, will give you a huge boost like you just added nitrous oxide.
you may see a little performance difference, but i don't think it would be a night and day difference.
If i'm wrong, someone please correct me.
