Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Redcat Racing Support
 Volcano SV - Default Factory Settings >
Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Old 05-21-2009 | 09:14 PM
Default Volcano SV - Default Factory Settings
What / how do I set default factory settings for Volcano SV?(idle / high / low)
Old 05-21-2009 | 10:04 PM
chevyderek72's Avatar
Default RE: Volcano SV - Default Factory Settings
The high speed is the tall one in the gold sleeve, turn that in all the way, just till snug not tight or you'll break it. Then the low speed needle is on the side of the carb, the side that rotates (opens). Set that at flush with the collar, then the idle screw is right in front of the carb. Make sure you have about a 1mm opening in the carb. Those are base settings, if you ever get outa wack or something go back to those settings and tune from there. Do you know how to tune?</p>
Old 05-21-2009 | 10:38 PM
perhamrocks's Avatar
ORIGINAL: chevyderek72
The high speed is the tall one in the gold sleeve, turn that in all the way, just till snug not tight or you'll break it. Then the low speed needle is on the side of the carb, the side that rotates (opens). Set that at flush with the collar, then the idle screw is right in front of the carb. Make sure you have about a 1mm opening in the carb. Those are base settings, if you ever get outa wack or something go back to those settings andtune from there. Do you know how to tune?</p>
make sure u turn the high speed needle back out 2 1/2 turns after u turn it all the way down.
i know thats what u ment to say chevy
Old 05-24-2009 | 10:49 PM
Whoops thanks man
