Hitec Servo arm ???
i have a Hitec-HS 5645 servo. the servo came with an aluminum servo arm that i would like to use but none of the screws it came with fit the threaded hole in the arm. does anyone know what size screw it would be.
MN
It's a goofy size that I've been looking around for, and thanks to your question, I found the answer! The good news is, you can still find them. They are fine thread by the way. Coarse theads are for the plastic/resin gears.
These screws are 2.6mm x 8mm
are we talking about the screw that holds it onto the servo itself? or the holes in the servo arm to connect a linkage to? If you have the screw to fasten the horn to the servo, try that screw and see if that threads through the other holes too.
