Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Newbie Question. Plugs Foul Out.
Old 01-17-2010, 02:12 PM
uniquestylz
Default Newbie Question. Plugs Foul Out.
Ok, so I don't have much nitro experience, but here is the problem that I am having. I have a Redcat Shockwave with the vx 16 engine. When I pulled out the plug, the coil looked perfect, but the rest of the plug was pitch black. I have noticed a little trouble starting the car, and a slight peformance decrease. What would cause this? Someone told me I could be using too much air filter oil, and someone else said maybe the HPI fuel has too much castor in it. I figured I would ask here because I will get the most useful answers. Thank
Old 01-17-2010, 02:43 PM
big mamou
Default RE: Newbie Question. Plugs Foul Out.
sounds like you running to rich
Old 01-17-2010, 02:49 PM
uniquestylz
If I leanit out, it won't hold an idle
Old 01-17-2010, 05:25 PM
Mickstix
Sure sounds like it's too rich.. Try leaning the high speed needle a little. HSN shouldnt effect the idle..
Old 01-17-2010, 06:40 PM
chevyderek72
chevyderek72's Avatar
Try putting all your needles back to factory specs, 2.5 on the high, flush with the collar on the lsn and a 1mm gap on the idle. Then tune your hsn from there, then your lsn.
Old 01-18-2010, 03:08 PM
uniquestylz
Well, it appears as though the motor was running lean, and it was pulling the oil out of the air cleaner. I changed the air cleaner, and now it's running great. Thanks for the advice. Just one question. How long should a tank of gas last?
Old 01-18-2010, 10:40 PM
chevyderek72
It depends, but around 10-12 minutes.
Old 01-19-2010, 12:46 AM
Mickstix
Glad ya found the problem! I hadnt heard of too much air cleaner oil being a problem before.. I'll have to make sure and not over saturate my filters!! Welcome to the forum!!
Old 01-19-2010, 09:42 PM
lvh
hey mick i did that once when i was new at it about 10 years ago, oiled the filter to much and the carb sucked it in the slid got all gooey and worked hard and slow.
Old 01-25-2010, 05:40 AM
jeztur2003
I usually use about 15 dots on mine.
