Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Volcano S30 Motor Issues
Old 02-06-2010 | 07:07 PM
Default Volcano S30 Motor Issues
Hi all,
Ijust came in from running my Volcano, and I am having some problems. I am new to the hobby, only having owned my Volcano about a month.
My Volcano is tuned almost perfectly, yet when I get on the gas hard it bogs down and sometimes dies. If I SLOWLY get on the throttle, it goes to full throttle no problem. Rusn like it should. It is almost like the Volcano is sucking in too much air from somewhere. The high end runs perfectly, and it smokes as it should. The only problem I have is that when I "floor it" it just bogs down and dies. After it dies, it is very hard to re start, almost like it has lost its prime.
I have replaced the fuel lines once already.
Any help is welcomed and appreciated.
Merc
Old 02-07-2010 | 12:26 PM
lvh
Default RE: Volcano S30 Motor Issues
Sounds like the low speed needle (lsn) needs tweeked maybe to lean.
Old 02-07-2010 | 09:29 PM
you have to tweak the needles depending on the weather every time you run i would say go a little leaner on hsn the hard stat may be due to flooding where are your needles set ie .2 1/2 turns from closed info like this will help us figure things out a little faster
Old 02-07-2010 | 11:25 PM
Did ya do the "pinch" test, from the other thread? What were the results? http://www.rcuniverse.com/forum/m_9463054/tm.htm
