gears/transmission
gears/transmission
im sure this question has been asked many times before, but i am wondering if i can get a spur gear with more teeth, or a clutch bell with less teeth, or maybe combine both? i have a stock volcano s30, and i want more low end power. any other suggestions for low end power would be great thanks
RE: gears/transmission
I think that these should do the trick for you Mark. Hope this helps.
Clutch Bell - http://www.hobbypeople.net/gallery/149525.asp
Bearings - http://www.hobbypeople.net/gallery/149559.asp
TX
This is the direct drive setup.
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php/products_id/149]http://allaboutfunhobbies.com/store/catalog/product_info.php/products_id/149[/link]
F.Y.I. That XTM Clutch bell is way to small to use with the stock Volcano Transmission. You'll top out on speed instantly.
that link is not working for me for some reason...im just looking for the right clutch bell/transmission combo to give me more low end power.....thanks guys for all the help
Take a look at this Mark. It comes with the bearings as well. AllAboutFunHobbies may correct me if I'm wrong again.
http://www.racers-edge.com/13T_Revo_clutch_bell_p/rce10433.htm
so is this one a bolt on that will work? if so what clutch shoes/spring should i get to go along with it? and is this bell compatible with a direct drive?
TX
That won't work. It's a revo clutch bell. The teeth are too small and too close together, the clutch bell is not deep enough.
The link man, I just tried it and it worked fine.
It's the link to what you are looking for. The single gear transmission and 13tooth clutch bell upgrade.
the link wont work, but it is quite possibly my computer....so ill check it tomorrow on my girlfriends computer
FL
Here's the pic from the site, but Im not sure what it is.. AAFH, is the direct drive something Redcat made for the Volcano, or is it just the single speed transmission for the buggies (Shockwave/Tornado) that'll bolt up to the Volcano?
i found a single drive transmission at http://www.rufaster.com/05126.aspx.....is that the one? just wanted to see what it looked like.....i would like to buy from allaboutfunhobbies because this is where im getting all the advice from....but i cant get the site to work....
FL
Your link to RUFaster is coming up as "item not found".. But here's the pix, of the actual parts,from AllAboutFun's site..
Single speed, (complete)direct drive transmission:
13T "vented" clutch bell w/bearings:
i know i may be annoying some of you right now, but i try my computer,my buddies, and my girlfriends, and i cant see the pictures on this forum, and the allaboutfunhobbies site dont work on eaither computer....and im trying to gather some parts and upgrades
im a idiot......i can only find 16 tooth clutch bells on that site for a volcano....and i cant find the direct drive transmission or the shockwave one....
TX
ORIGINAL: Marksv30
ORIGINAL: AllAboutFunHobbies
What's not working on our site? Orders have been coming in fine all day. Let me know what's the problem maybe I can fix it for you. I pmed you about it too.
ORIGINAL: Marksv30
Same here, wasn't aware of any issues but here is the link if you want to buy somewhere else thats fine too. Just wanted to clear up the web issue, kind of freaked me out...LOL.
