redcat gears MOD
hi guys. i lately found out that there is a differance in pitch between module and "standard pitch"
module is metric and "pitch" is standard. this is why so many of our customers are stripping their gears. PLEASE HELP OUR CUSTOMERS AND MYSELF! does anybody know what module redcat gears are? NOT THE 1/8 BUT THE 1/10 i know the redcat pinions oon the 1/18 are .8 module please and thanks! |
RE: redcat gears MOD
the epx, epx pro's and the caldera 10e all use a 48 metric pitch pinion gear.
just went thru 4 gears figuring this out on my sons volcano epx. figured out that it is 48 pitch metric not standard. 48 pitch metric is also know as .6 mod or tamiya pitch.
scroll down to the .6 mod gears"48 pitch metric". http://www.robinsonracing.com/catalo...tchpinion.html |
yep, i just looked on redcats site to figure it out.
look up parts for the epx and under pinion you will find 3 different sizes, all with 48 metric pitch. would kinda be nice if some day all rc's ran the same pitch. there are so many! 32 and 48 standard are common. so is 1.0 mod. some redcats have a .8 mod. then there is whatever my F1 pan car has(unsure of the pitch but its very small teeth) |
i do know this but nobody but redcat that i know of sells them and i know that mod is metric and much easier to find than a metric 48 pitch pinion. that's why this is so hard. i know that roinson racing carries a couple but nobody carries the metric ones here.
do you know of someone that does? a website that carries steel would be greatly appericeated!
i linked a robinson racing link that has 12 tooth to 24 tooth. robinson numbers are 1112 to 1124 on the volcano i couldnt go lower than 16 t cause the motor hits the driveshaft.
ps i ordered mine from toadzrc.com they stock 14,15,17,19 for $2.98 each |
um hows the shipping? broke student....
i bought a 17 and 19 tooth and it was like $8 total with shipping.
Can you confirm that the Caldebra XB 10E use a Metric .6 MOD?<div>
</div><div>Robinson Racing 1113: Metric Steel Alloy 48 Pitch Pinion 13 Teeth </div><div></div> |
ORIGINAL: nitrosportsandrunner the epx, epx pro's and the caldera 10e all use a 48 metric pitch pinion gear. |
| All times are GMT -8. The time now is 05:26 AM. |
