RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   volcano back in action! (https://www.rcuniverse.com/forum/redcat-racing-support-427/10470861-volcano-back-action.html)
nitrosportsandrunner 04-18-2011 05:02 PM
1 Attachment(s)
after a winter time bash with a vxl system on 3s in the cold weather, the volcano had some cracked plastic parts and needed some help.
so hear it is, i put an ezrun system in it. upgraded the steering knuckles and the rear hubs to alloy ones.
replaced an a-arm, spur gear, "C" hub and camber link.
tried fitting an old evo body on it. kinda looks cool.
electricrc68 04-18-2011 05:10 PM
RE: volcano back in action!
looks cool with the evo body on!
soldier5050 04-18-2011 05:29 PM
That is cool ! Love the color blue ! Very Sharp My Friend!
rsw007 04-19-2011 02:21 AM
looks good. how well does that 380 motor pull that truck?
All-or-Nothing 04-19-2011 03:33 AM
Nice truck/Evo......looks like a fun ride.
nitrosportsandrunner 04-19-2011 05:09 AM
ORIGINAL: rsw007
it does fine. its the same motor that comes in the larger cladera 10e!
i have used this motor also in a kyosho blizzard(tracked rc) without issue.
it may not hit 70mph on 3s lipo like a vxl motor(true 540 sized an) but it can do 50mph and not overheat at all.
same with the ESC. its rated at 35amp, but performs as well as a 70-90amp ESC's i have used.
rsw007 04-19-2011 01:11 PM
which turn motor did you go with and what pinion gear? i installed the 8.5t 60amp on my sons volcano with 17t pinion and its pretty quick with 2 cell lipos. cant wait to try 3 cell. i ordered the 9t 35 amp kit first but didnt think it would be strong enough so sold it to a friend for his sons rustler before even trying it. But in the rustler it runs 65mph on 3 cells. ;)
nitrosportsandrunner 04-19-2011 01:23 PM
ORIGINAL: rsw007
its the 10t 3900kv motor.
using the stock epx pro pinion gear for the volcano.
these 35amp ESC's are underrated. granted, the 60amp is a better choice. it never hurts to have a speed control that is more than what you need.
and even tho the motors are really 380 sized finned out, they provide plenty of torque for a 4wd the size of the volcano.
rsw007 04-19-2011 01:44 PM
how would you rate the durability of your volcano v/s earthquake 8e? really wanting a eq8e for myself.
nitrosportsandrunner 04-19-2011 02:29 PM
ORIGINAL: rsw007
thats a tough one. my earthquake 8e has actually broken more on me, but then its larger/heavier and faster.
kinda comparing apples to oranges there.
the volcano with a brushed system on 2s lipo will do high 30mph range. the earthquake will hit 45-50mph.
the super larger tires on the earthquake put alot of stress on the stub axles and the steering.
no issues yet with anything else tho.
on the volcano, i have bent or broken a couple of dogbones, broken a rear hub and a "C"hub. no drivetrain issues as of yet. others have stripped the diffs, but mine have held up fine. pretty amazing for a brushless 4wd with no slipper clutch.
