looking for tire options and more
so i know the volcano has a 12mm wheel hex, any good 12 mm tire whell combo out there
and bodies what else would fit? and shocks......say would shocks from a emaxx work?? if not what would work anything else ya guys can think of post up in here thanks |
RE: looking for tire options and more
1 Attachment(s)
ORIGINAL: bdyman so i know the volcano has a 12mm wheel hex, any good 12 mm tire whell combo out there and bodies what else would fit? and shocks......say would shocks from a emaxx work?? if not what would work anything else ya guys can think of post up in here thanks |
the brushless motor and tranny is stock geared, i found some jato wheels thats a 12mm hex
oh, didn't realize it was brushless. The Jato wheels I think are smaller than what I have. I think they're considered 2.2 size rims. You'll probably need a bigger pinion gear.
<font size="2" color="#00265e">Dads like rc too</font> & <font size="2" color="#00265e">bdyman</font>
i believe Jato wheels are 2.8's they would be a good replacement but tire wise i think the jato has ribbed fronts so you would need 4 rears from the jato. |
1 Attachment(s)
yeh, the jato 2.8 rears should be pretty decent. they are still a bit smaller than stock tires, but if you up the pinion gear 2-3 teeth it should make up for that.
i put stampede 2.2 rear rims with proline masher 2000 tires on mine. |
nice i like it, ok so just look for a 2.8 size tire then correct???
what about shocks and bodies |
2.8's or 2.2's will work as long as they are the right offset and have 12mm hex,,,, Or i guess pin backed wheels will work too but id prefer to leave the hexes on. I tried my HPI 2.2's tonight and they dont fit, the wheel is not larg enough around and the offset is in to far for the fronts to fit so try and stick with 2.8s
well if the jato wheels will work no problem ill pick those up, found some for 20 bucks
so what about the bodies and the shocks will a emaxx body fit or emaxx shocks fit |
ORIGINAL: bdyman well if the jato wheels will work no problem ill pick those up, found some for 20 bucks so what about the bodies and the shocks will a emaxx body fit or emaxx shocks fit An emaxx body is much to long for the volcano. A body meant for the stampede should be close tho. much closer wheel base on the 2 trucks. |
well i guess i should ask the question would any 1/10 scale shock work on the volcano
do you know if that bug body in your sig has the right wheelbase for a rustler? after i sell the volcano chassis i think im going to buy either the semi body or the bug body for the rustler.
| All times are GMT -8. The time now is 03:32 PM. |
