Big crash
Today i was pushing my car to max speed and suddenly it was too far away for my transmitter to control it. At maximum speed it drove for like 15 more meters and then crashed into a hydrant.
http://mieszkancy.ds.pg.gda.pl/~jimi/auto/warhead/ <- scroll down to The crash :) I had some luck though. The only thing that broke was one fuel tank mounting and two reveiver cap mountings. Took almost all parts apart and put them back together , works like charm :). Notice engine head is smashed (it left a small sign on hydrant). I think that the whole impact energy was taken by the engine, thats why chassis was a bit bent :) All in all, this thing is very hard to crack |
RE: Big crash
Right on jackkpl !!!!!!!!!!!
That's how you really have fun... at least when I play with my toys:D I ain't happy or I've not had fun untill I punish these babys. No mercy for the weak!!!!!!!!!!!!!!!!!!! |
RE: Big crash
All I have to say is wow... [sm=eek.gif]I feel kinda bad for the head on your engine, that thing is all crumpled up.
Good job man |
RE: Big crash
a big crash everbody i found it in old forums - unluky
RE: Big crash
Very nice, the hammer will fix all:D
RE: Big crash
cooooool:D:)
RE: Big crash
nasty!! well my advice is to go out and buy a FAILSAFE NOW!!
RE: Big crash
i second that.:D
RE: Big crash
You guys all have problems with your plastic spur gears? Do you think they were set up wrong?
RE: Big crash
If you are stripping your spur gear you havent got the mesh right. Put a piece of paper between the clutch bell and spur gear before you tighten the engine mounts down. It should run nice and smooth without any hint of binding.
RE: Big crash
Thanks I read that I havent recived my car yeat but have all the plans to take it apart and properly reassemble it when it comes in. I saw jackkpl was striping his gears and thought that it might be because of the mesh It sounds like you can here them wine in one video!
RE: Big crash
that is y u spend the 20 dollars or so and get the failsafe that is the first thing im getting 4 my truck b4 i even fire it up so i dont total it out lol!!
| All times are GMT -8. The time now is 05:08 PM. |
