RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   REAR GEARBOX PROBLEMS!!!!! (https://www.rcuniverse.com/forum/redcat-racing-support-427/4572186-rear-gearbox-problems.html)
BJBaxter22 08-01-2006 06:26 PM
Hey, it looks like i really screwed up, after a day of driving, i find out that the right rear wheel isnt spinning with the rest. Maybe a stripped gear in the rear gear box? Any help is greatly appreciated!!
bluecaka69 08-01-2006 06:42 PM
RE: REAR GEARBOX PROBLEMS!!!!!
check dog bones i spun the end off several of them
check this out http://www.rcuniverse.com/forum/m_41...tm.htm#4194921
dog bone stayed in drive cup but wasnt spinning
BJBaxter22 08-01-2006 06:57 PM
no the dog bones are fine, but it seems like its not grabing in the gear box. Thanks Though!
futabaed 08-01-2006 07:03 PM
Time to take that rear diff apart and check the teeth!
bluecaka69 08-01-2006 07:14 PM
also check the grub screws that hold drive cup on gearbox
chubbysuncle 08-01-2006 09:05 PM
Sounds like your rear diff is stripped out. Have you been doing alot of jumps? Landing at full throttle or full braking will tear up a differential quick. Both diffs are stripped on the kids Volcano right now. Waiting for the pinions from Clermont. Take the diff apart like futubaed said and look for chipped or missing/ worn teeth on the pinion and ring/big gears. If they're OK take the 4 tiny screws out of the big gear and open the diff itself. Check the spider gears and plastic housing for damage. If my stuff comes tomarrow I'll try and make a post to the FAQ with pictures of the rebuild for you.
BJBaxter22 08-02-2006 01:08 AM
Thanks for all of your help!! I opened up the r.diff. and the pinion and ring looked ok, and because im a novice, i didnt want to open up the rest untill I found out for sure thats it. do the front and read diffs. work the same? if you lift the rear end and push the front wheels forword, should both rear wheels spin, or just the left? my dad thinks its fine and working good because when one rear wheel is spun forword, the other spins back and so on. I really do appretiate your help though!!:D
-Brian
BJBaxter22 08-02-2006 01:09 AM
oh yeah, no havent been doing jumps. Its brand new with about 5 tanks through of breaking in on pavedment and a little bit of grass driving.
Popper252 08-02-2006 12:59 PM
If you spin both front wheels forward both of the back wheels should spin forward aswell.
If you spin one back wheel the other back wheel should spin in the other direction.
good luck buddy.
futabaed 08-02-2006 01:59 PM
With the front end if you spin 1 wheel on the front while your holding the truck the other front wheel will spin the other direction,
Same Thing when you do it to the back wheels.
When you spin both rear wheels at the same time both the front ones will spin the same direction.
Please let us know if this helps ya out.
glk420247 08-13-2006 08:23 PM
I had this problem also, with the right wheel not wanting to spin. I thought my rear gears wear stripped also, but I remebered that I really tighten all the tires down. I think I had them to tight, because I loosen them alittle and it know works fine. I also used lock tight on the bolts.
GReg KEiffer
Nitroguy87 10-05-2006 10:09 PM
Have you by anychance checked that little tiny screw on the drive shaft?..My Volcano Stx had a BAAADDD problem with that coming loose..I went and screwed it back down..And a drop of superglue..Perfect now :D
muse13 01-21-2009 10:29 AM
I have destroyed my differential gears on my volcano sv. There is a 35 tooth gear and a 17 tooth gear. The 35 tooth is the gear that needs to be replaced. Is there any one who offers a steel upgrade? If not where is a good place to find replacement. Also how do you know if your spring in your clutch bell is ok? It seems like it is hard to find hop ups for the volcanos transmission. Has any body installed a second gear? What other changes do you have to make if you install a second gear? Thanks for your input. I am a novice and hooked.
chevyderek72 01-22-2009 01:28 AM
Wow brought from the dead haha. hey check out this thread, http://www.rcuniverse.com/forum/m_7305969/tm.htm
i would go with the direct drive, great upgrade, since you gotta get a new spur anyways, just spend a little more, you'll be happy
muse13 01-22-2009 03:23 PM
thanks for the info, cant find a picture of direct drive. what goes away with install? I have single speed now
perhamrocks 01-22-2009 10:34 PM
the direct drive is exactly what it says, it's a gear that is directly on the main drive shaft. it just takes out all of those excess gears, and give it more torque and speed, check out tihstae's link, and then there's another link in there to purchase it.
