vx.18 engine wont start
engine was running fine and all the sudden it died and wont start. i think im losing compression but not sure. any help would be great.
RE: vx.18 engine wont start
check the glow plug they do burn out often
is your glow plug good? and did you have fuel(dumb question):D. make sure your screws are good and tight. you could have a cut fuel line. That would cause the engine to stop and not start. or your screws that hold on the coolong head could be loose. its possible. Happened to me. Could be your prob, but i htink its the fuel line. check it.hope this works:D
did it make a noise or anything when it died like a pop sound if so you may want to tear the motor down and check the conrod but if it just died its probably the glow plug
all you got to do to check the fuel lines is take off the one that connects to the exhaust and blow in it with fuel in the tank it should blow fuel up to the carb if it doesnt check your o-ring in the gas tank
ORIGINAL: nitrospeed33 is your glow plug good? and did you have fuel(dumb question):D. make sure your screws are good and tight. you could have a cut fuel line. That would cause the engine to stop and not start. or your screws that hold on the coolong head could be loose. its possible. Happened to me. Could be your prob, but i htink its the fuel line. check it.hope this works:D |
If none of that works check your tunning, if your running to lean you maybe getting burn off, where the nitro evaporates immediately and the oil boils out of the fuel line as soon as it hits the carb. Your engine is WAYYY to hot if that is the case. Had that happening to me with a Traxxas Rustler along time ago, couldn't figure out why it would die all of a sudden and then not start for a long time.
im getting fuel and the put a new glow plug, when i try to start it sounds like theres no compression the string is too easy to pull. anyone have trouble with their engine internally yet?
it might be the one way bearing on your pull start it might not be catching on the shaft
thats what it sound like is bearing in the pull start they have been known to go bad often also
I agree with zack221. it sounds like the one way bearing. but if that dosen't work then I think its a loose bolt on the cooling head or something.good luck:D
here is a new one way bearing if yours is wore out you could also take the motor off and take your pullstart off just becareful and dont let the spring come unhook and smack you in the head
http://www.rchover.com/inc/sdetail/44762 |
ive broken the engine down and put it back together all bolts are tight. the pull start bolt is messed up it doesnt free spin anymore, so pull start is off, i can spin the motor with a cordless drill, it spins but wont start and i know its getting gas cause it poured out when i broke it down. i have two .18 motors so i may swap the pistons see if the older one will start then. if not i may have to get a rebuild kit for it. its not an old motor maybe 1/2 gallon through it. ive put all hpi parts where i can, is there a similar motor in the hpi traxxas brand i could get a piston from?
what pull start bolt are you talking about the one way bearing?
do you have the glow plug igniter charged
the one inside the strig pull start there is a one way bolt attached to the pull string its not a one way anymore it doesnt free spin.
the one way isnt supposed to spin it is supposed to catch on the shaft
it is suppose to spin clockwise and free spin counterclockwise, thats not a big issue i can spin the engine to start with a drill. but it just has no fire and glow plug is hot (new) the heat sink is tight everything is as it should be i think but no fire.
also check for air leaks seal the backplate and the base of the carb with high temp silicone and you also may want to take your carb apart and make sure it isnt clogged
have you taken the new glow plug out and stuck it to the glow plug ignitor it should glow red
it could be losing comp. in the backplate ill try that.
1 Attachment(s)
your tuning may be way off so you could try retuning it here is a simple way i also posted it in the faq thread
ccw means turn the screw counter clockwise cw means turn the screw clockwise lsn-ccw richens and cw leans hsn-cw leans and ccw richens idle-cw opens the gap and ccw closes the gap Set air gap of throttle 1.5 mm,(idle screw), HSN Cw til it bottoms out then 3 1/2 turn CCW. LSN Flush with the throttle housing + 1 turn cw. Try to start, will be runnin really rich, if it starts. Turn down idle speed, then adjust HSN cw til you have good acceleration to idle. if your idle speed rises, turn it down. May have to do a couple times. Last adjustment LSN, turn cw slowly til idle speed starts to rise. when it rises you're running lean, turn it CCW till idle speed just drops. Blip the throttle you should be acceleration ok with some smoke coming from the muffler.Lean the HSN 1/8 turn CW till your satisfied. i also posted a pic of the motor |
| All times are GMT -8. The time now is 06:33 PM. |
