no second gear
i have a tornado xp and its holding up great but i have no second gear.
i have searched this and still cannot figure out what is wrong. can someone post a diagram or some detailed instuctions about how this setup works? is there a spring or somthing that makes it ingage? that little screw adj when it shifts but i really dony know how. just need a little help, somthing must be broken. btw how many turns out do you guys have your screw? thanks and merry christmas |
RE: no second gear
Make sure you adjust the right screw, there are 2, on holds the shifter on the shaft and one controls the shift. The center one it the one that holds it on the shaft and should be hard to turn counterclockwise. I would suggest to turn the shift adjuster 1.2 turn counter clocwise then try it, do it again and again until you get it to shift. Dont do it too much otherwise you might loosen too much and the spring will pop out, you may have a bad shifter too, i had one and had to replace it. let me know what happens.
RE: no second gear
i know im turning the shift screw, i can feel the spring under the screw. i had it tight and ive had it so loose it could have come out. no shift either way. what breaks? how do i fix it? thanks
RE: no second gear
buy a new on from clermontmotorsports.com, i think they come with a bad spring inside sometimes, its not worth taking apart just to try and fix. get a new one, spray some lube on it and put it in and you will be fine, make sure that your not in second gear too, you can usually tell since its slow on take off. I would suggest the upgraded clutch bell and clutch spring too, check out the sticky on top.
RE: no second gear
buy a whole tranny?
is it somthing that is imposible to fix? what does that little screw-spring adj? |
RE: no second gear
not the tranny, this part: http://www.clermontmotorsports.com/s.../Detail?no=125
The little spring control the about of tension on an arm, when the transmisson spins fast enough, the arm is forced out to grab the second gear spur, it is hit and miss with them, i have 2 xp's , 1 has shifted fine from day one and one had to be changed, easy fix for $3.50. Sorry bro, you can try to fool with the setting some more but i wouldnt break the transmission down to try to fix it, your better off replacing it. |
RE: no second gear
cool i got to order a bunch of stuff from him anyway.
thanks for the help, i must have a broken set up. i think it is in second gear also. thats why i broke a clutch spring. easy install? |
RE: no second gear
yeah, easy to install but dont get the factory clutch bell or clutch spring. you do need to get the factory gear changer though.
RE: no second gear
1 Attachment(s)
Hope these photos help and don't loosing the screw to much.
RE: no second gear
1 Attachment(s)
Here is some more hope they help. Eric and have fun and enjoy! And I got these off a post that was done by someone else.But like I said hope it helps!!!
RE: no second gear
I knew there was a reason I like sticking with single speed transmissions..
RE: no second gear
Those pics are from clearmontmotorsports he does an excellent job with the pictures and description deptment.
RE: no second gear
thats perfect! thanks 4 all the help.
ill order some stuff from cms.com as soon as he gets some front A arms in. dont want to pay shipping twice. |
| All times are GMT -8. The time now is 05:23 PM. |
