gearboxes
i noticed while taking apart my truck my gearbox was extremely dirty and dry inside, how can i clean it and what do i put inside for lubricant after cleaning, thanks
RE: gearboxes
do you mean the front and rear diffs, if so use gear lube
RE: gearboxes
yea the big black gear boxes, i had no clue they had an open side underneath and when i took a look it has so much dirt inside it makes a crunchy noise when i spin the tires, how much gear lube?
RE: gearboxes
grease is what i meant, gear grease. make sure all the teeth are covered well, after you clean them
RE: gearboxes
ok kool,do i use wd 40 or somethen to clean it though
RE: gearboxes
wd would work good to clean it
RE: gearboxes
great. thanks for the info
| All times are GMT -8. The time now is 01:54 PM. |
