RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   .18 vx help (https://www.rcuniverse.com/forum/redcat-racing-support-427/5818756-18-vx-help.html)
chopper8984 05-06-2007 03:38 PM
.18 vx help
i have a tornado xp with the .18 vx in it and im haveing a problem with it the screws on the back plate keep comeing lose. as soon as i start it up i only run it for 2 min and it starts stalling and geting weak and starts getting hot quick i tighten them as hard as i can and they still come lose any help would be great also would the backplate losening its seal make the motor run hot and lose power ? im new to nitro so any help would be great
123michael 05-06-2007 04:10 PM
RE: .18 vx help
does your engiene cut out?if it doesyou need to ritchen the high speed needle.thats why its getting warm.
and for the backplate coming louse just put thread lock on ,lol:D
Chubbysdad 05-06-2007 04:16 PM
RE: .18 vx help
Here is a good article to read. Michael take a look also lol.. http://www.rcracersedmonton.com/rcra...Engine101.aspx
RangerArlin 05-06-2007 05:50 PM
RE: .18 vx help
Yea chopper I'd get some threadlock asap. Im pretty new to the sport as well and have learned very quickly that if theres a screw somewhere, it needs to have threadlock on it. Get the Blue threadlock not the Red. The red is permanent and could make you have a bad day if you need to get the screws out. and as far as tuning goes, there are some other really good threads in this forum that helped me out. Good luck to you man.
123michael 05-06-2007 05:53 PM
RE: .18 vx help
i have red thread lock,lol
chopper8984 05-06-2007 06:57 PM
RE: .18 vx help
what happens is it starts fine and will run good for 2 to 3 min then the backplate get losse and it gets warm and all kinds of oil dumps out of the backplate and it starts to lose power and finaly it will just stall when i hit the gas befor the back plate was getting lose it never got hot and it would run great right now i have been running it a lot at night and it has been nice and cool outside with low humidity and 55 outside and 20 to 40% humidity thats the only time i realy get time to play with it
ehroof 05-06-2007 07:00 PM
RE: .18 vx help
put the backplate screws back in with blue locktite and you should be fine. it sucks in air as it comes loose and the engine is leaning itself out thats why it runs hot. once you seal the backplate you will be fine.\
123michael 05-06-2007 07:36 PM
RE: .18 vx help
realy god you learn somthing everyday lol
mozzzy_2000 05-07-2007 01:04 AM
RE: .18 vx help
yeah get some blue crv sealant and use some blue thread lock and do it ASAP. That should fix ya up. Hopefully no damage has been done but if you allow that to continue you can dirt sucked in. And Michael be dam careful of red threadloc hey! I have had mega problems removing screws and I have stopped using it.
123michael 05-07-2007 05:56 AM
RE: .18 vx help
lol i dont use it on eny thing exept the engiene mount.my friend gave it to me.i load of it in a tube his dad works on cars.:D:D
mozzzy_2000 05-07-2007 07:02 AM
RE: .18 vx help
WOAH red automotive loctight??? hmmm be careful my friend! I used red on the engine mounts and had to use extractors to get them out. NEVER again! lol
123michael 05-07-2007 07:24 AM
RE: .18 vx help
no you start the engiene and the threadlock goes warm.then the thread lock melts its easy.;)
chopper8984 05-07-2007 12:48 PM
RE: .18 vx help
ok i got it all taken care of and i check for air leaks none now i have a new problem. i tryed running it today when it was a bit hot outside around 85 to 90 and it hated it i riched it up and it climed to 250 in a matter of 3 min. but last night i ran it when it was nice and cool out mabey 50 outside and it never got over 200 and it ran like a charm but with this warm weather it wanted nothing to do with it
i know i do need to get a new glow plug the one i have is looking a little used up could that be one of my problems and if so what do u guy say is the best glow plug for this engine i use 30% nitro 12 % oil should i be buying a higher oil content fule or use a lower nitro contant fule also i had somthing really wired happen to me yesterday while i was trying to tune it for the day the glog plug popped right out but i checked the threds on the plug and the head and they where al right so im guessing it just got lose and poped off it ran fine when i put my old plug back on it later that night
RangerArlin 05-07-2007 01:59 PM
RE: .18 vx help
Good ol trial and error huh? haha. Everyone on this forum will recommend the os A3 glow plug. its a hotter burning plug and it works great man. They're like 4 bucks at your lhs. As far as your fuel goes, im not sure. I run 20% nitro and 12% oil and have never had a problem. I guess if you're gonna stick with that fuel just keep it little more on the rich side, low and high speed needles.
123michael 05-07-2007 04:06 PM
RE: .18 vx help
lol,at least its cold over here lol
