RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   redcat lightning shifting problem (https://www.rcuniverse.com/forum/redcat-racing-support-427/5912755-redcat-lightning-shifting-problem.html)
jcervantes11 05-28-2007 03:14 PM
Hello guys, I am new to this hobby and I have a lightning from redcat. It doesn't shift gears, yet its a bit fast. Some guy said
it is faster then my other car which its a traxxas rustler. Now I busted two teeth on the big gear of throttle number 6 on the manual which is on 15th page under sleeve pipe of throttle. Can anybody help me to get a new one from different brand and why this happens and how
to fix the tranny to shift on second.
thanks
AllAboutFunHobbies 05-28-2007 05:31 PM
RE: redcat lightning shifting problem
There is a clutch in the transmission that has an arm that kicks out when you hit a certain RPM, you have to adjust the set screw till you get it to the tension that lets the arm kick out in the proper RPM range. Also about the Spur gear stripping you should replace your clutch bell with an updated version to avoid the stripping of the gears. The aluminum clutch bells get hot running against the aluminum clutch shoes and warp causeing the clutch bell to be out of round and strip out the transmission gears.
This should be the gear you need for the main spur gear:
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=2_42_44&products_id=772]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=2_42_44&products_id=772[/link]
Clutch Bell and Clutch Bell Gear Upgrade:
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=412]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=412[/link]
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=415]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=415[/link]
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=413]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=413[/link]
Chubbysdad 05-28-2007 06:01 PM
There are no other replacements for the gears as of yet. Here is a link for part number 02040 http://www.clermontmotorsports.com/servlet/Categories
jcervantes11 05-28-2007 06:42 PM
Thank you i cant really do much in this minute until i receive my check but i'll work on. Thanks
cdextreme 05-28-2007 06:45 PM
Sorry to post this here but is my eldorada/volcano the same with the trans? @ gears i mean. If so how can you tell when its running. i.e. sound
jcervantes11 05-28-2007 07:14 PM
isn't thats the break? Also I took apart my clutch bell off, does the spring suppose to pop off?
Chubbysdad 05-28-2007 07:16 PM
no if it pops off it is broken. You need to replace it.
AllAboutFunHobbies 05-28-2007 08:06 PM
ORIGINAL: jcervantes11
No it shouldn't pop off. You need to replace it and I would suggest the Traxxas 4146X spring mroe durabel and a better stale rate. You don't use the Traxxas clutch shoes though, you throw them away and keep the spring.
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=242]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=242[/link]
Two Piece Clutch Shoes
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=700]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=700[/link]
Clutch Spring
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=410]http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_24&products_id=410[/link]
Chubbysdad 05-28-2007 09:31 PM
when your ready shoot me an email. I have a spring and clutch shoes that will fit that are an upgrade..
