RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Ive found a problem (https://www.rcuniverse.com/forum/redcat-racing-support-427/5925866-ive-found-problem.html)
bluecaka69 05-31-2007 11:02 AM
Ive found a problem
So I was out runnin the trmoer buggy today and at high speeds it kept on cutting out so
first thought was to lean or to rich so I messed with settings for awhile and came to the conclusion thats not the problem
second thought I seen air bubbles in fuel tank and line so I continued to makes sure everyhting was sealed properly and no air was getting into line i installed new fuel line problem not solved
By now I was getting pissed and could not figure it out so took th tank out and notices it rides directly on the chassis NOT GOOD i put some O rings between the chaasis and fuel tank BAM problem solved
After further investigation it turns out that the vibration of the chaasis was tranfering to the fuel tank h=thereofre causeing the fuel to be shakin up and creating air bubbles at high speed causeing car to run super lean and cut out
Hope this helps out someone in the future
{GBI}Harryball 05-31-2007 11:24 AM
RE: Ive found a problem
I have a friend with a tornado bb that has air in his gas lines, ill have to pass this info on to him. Thanks for sharing:D
Chubbysdad 05-31-2007 12:58 PM
Good fine blue. I will check out mine.
ENR_Kyle 05-31-2007 01:27 PM
nice find, should bring it up with redcat, they can just throw some rubber washers betweent he tank mound and the tank to rais it a few.. or do what you did.. this is the kind of support a new company needs. helpin work out the bugs.. nice.
cdextreme 05-31-2007 04:35 PM
I had the tank oof my eldorada and it had them installed around the screws already.
G*Man 05-31-2007 09:09 PM
ORIGINAL: bluecaka69
This miss, did it occur near top end? like it would cut and never get past that certain rpm, kinda like a rev limiter?
bluecaka69 05-31-2007 09:16 PM
It sure did
ORIGINAL: G*Man
yes the other redcts have the o rings to stop vibration but the tremor the tank is screwed on right threw the chassis and no o ring
