good receivers
i need a new reciever for reslly cheap like as cheap as possible with it still being good enough i don't race just bash if that helps
RE: good receivers
i went with traxxas in mine.. and i liked it, but i like traxxas products, i got my rx/tx for 15 shipped..
RE: good receivers
RE: good receivers
for either of those recievers can i just put the old crstyal that came stock and use the stock remote?
RE: good receivers
i used my old crystals, but i switched both, rx and tx.. but for some reason, when i put my crystals from my rusty into the pede tx it wouldnt work, and it wouldnt work the other way around either.. so i dont know if it was something to do with the controller or not.. but you prolly could keeping the controller and upgrading the rx
RE: good receivers
i've got a traxxas reciever laying around so i'll use that but i lost the throttle linkage and horn is there anything i can use when i'm waiting for the parts to come in?
RE: good receivers
im sure your lhs has one that will fit right on.. atleast the horn, the linkage you can make one out of the really cheap hangers that u get from like a dry cleaners. their the thinnest ones, not the typical metal hangers, their usually white, and the same thickness, maybe a tad, very little bigger than the stock.
RE: good receivers
it also depends on frequency if rx is 75 mhz then a 72 mz crystal wont work they all need to match
RE: good receivers
ahh, see i dont know what the stock is.. but i wouldnt think the freq's would be different in the 2 traxxas rx/tx's but they might be just so they dont interfiew besides by the crystals
RE: good receivers
its ok if the crstyals won't work with the taxxas becaus i have the crstyals for the traxxas reciever and transmitter 2. i guess i will wait for the parts to come in becuase the next time i'm going to my lhs is after the parts come becuase my lhs is 30min away so i can't go there daily
| All times are GMT -8. The time now is 12:04 AM. |
