shockwace linkage?
does anyone have pics of what the linkage should be set at and what are some of your guys low speed, high speed and idle screws set at?
RE: shockwace linkage?
i am not too sure what linkage your talking about but set the high needle to 2 1/2 out from closed and the low needle flush with the collar around it, this will get you going, i am sure you will need to tune from there.
well as far as linkage the throttle cable and etc
here's pic of the throttle linkage from a lightning but they are the same: http://www.redcatracing.com/picsgallery/lightning7.jpg
because i think mine is all screwed up, and I cant figure out why it wont run, everything else is where it was before, and the manual says if your engine doesnt start to check the linkage.
i think it means to make sure there is a 1mm gap on the carb when at the neutral position, if the carb is closed it wont start.
| All times are GMT -8. The time now is 10:34 AM. |
