buggy problems
whenever i go to open the buggy wide open it just boggs out. it will drive fie untill i pin it and then it bogs. any sugestions to why its doing this
RE: buggy problems
Sounds like it may be running lean, try turning the high jet out an 1/8-1/4 turn and see if that helps.
RE: buggy problems
no its not lean i have it 2.5 turns out. its still breakin it in a little. this is the first time i have tryed to open it up. it usaly bogs but if it dosent it just dosent wind out[:@][:@][:@]
RE: buggy problems
2.5 out is lean I have the VX.18 motor and mine is set at 3 1/4 out you need to richen it up.
RE: buggy problems
if the pitch of the engine doesnt go up, like max rpm's you may need to lean it a little. do it 1/8 turns at a time and run it around before you adjust it more.
RE: buggy problems
ORIGINAL: Macanan 2.5 out is lean I have the VX.18 motor and mine is set at 3 1/4 out you need to richen it up. |
RE: buggy problems
oh and about how many tanks should it take to brak it in????
RE: buggy problems
5 at the min.
RE: buggy problems
thanx for the tips . ill try to lean out my engine a bit after a few more tanks and see if that changes anythink
RE: buggy problems
Ok i haven't got this break in thing either.... so when you do these 5 tanks... on each tank you just do some figure 8's being gentle on the throttle untill the next tank and so on, then when thats done you can tune and let er rip..???
RE: buggy problems
thats pretty much it in a nutshell, you use the throttle a little more on each tank. let it cool between tanks with the piston on the bottom of the cylinder when cooling, its also a good habbit to get into doing, leaving it at the bottom when its hot and not being used.
RE: buggy problems
ya i did all that. i ges i just have to lean it out some more
RE: buggy problems
ah ok, its all clear now, lol.. ty ehroof
| All times are GMT -8. The time now is 05:00 AM. |
