RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Reverse in a Nitro (https://www.rcuniverse.com/forum/redcat-racing-support-427/6918940-reverse-nitro.html)
webbl19 01-16-2008 07:37 PM
Reverse in a Nitro
My buddy showed me this last night when we were browsing you tube. Anyone know how this guy got this to have reverse? We have a idea that envolves a electric motor but it would take some work.
http://youtube.com/watch?v=g07LgRWAmjc
ehroof 01-16-2008 07:39 PM
RE: Reverse in a Nitro
it comes like that, my tmaxx has reverse stock, alot of people take it out though, seems to cause problems over time.
webbl19 01-16-2008 08:57 PM
I didnt think any nitros had reverse. Learn something new everyday.
AllAboutFunHobbies 01-16-2008 10:10 PM
Reverse is over rated. 95% of the vehisles we get to work on are cars with reverse that doesn't work and the transmision is stuck in reverse or the thing won't go back into forward. there a disaster.
ehroof 01-16-2008 10:22 PM
even though they are a problem, its pretty cool to do a wheelie in reverse, lol
xjedix 01-16-2008 10:25 PM
My neighbor has reverse on his tmaxx. It is a great feature as long as it is working as intended.
Question on that video: Do those have 3 forward gears or are they counting reverse as a gear??
AllAboutFunHobbies 01-16-2008 10:42 PM
ORIGINAL: ehroof even though they are a problem, its pretty cool to do a wheelie in reverse, lol
this is true, it's very cool to do wheelies in reverse. I have to agree with that.
willashcroft 01-24-2008 11:03 AM
You can buy a reverse gear for the hpi savage. it bolts straight onto the gearbox.
it would be rather cool to get one for the tornado or tsunami. :)
I think we Should recycle old posts. They can tell people more info :)
dominicevans 01-24-2008 11:35 AM
i would luv a reverse in my buggy cuz i dont like having to turn it around when i am blocked by an object but if they dont work well then forget it
Kemo 01-24-2008 02:05 PM
The best reverse setup was by kyosho, called the QRC
QRC (Quick Reverse Clutch)Unit
This simple construction consisting of five gears, shafts and a clutch arm, allows any two channel, two servo, radio operated, engine powered car to drive forward and backward just like the full-scale counterparts. Engine power is transmitted via the spur gear to the forward and reverse drive gears. These rotate the clutch gears. Depending on your throttle inputs, the throttle servo-controlled clutch arm engages either into the forward or reverse clutch gear. The clutch gears transmit the power further on to the front and rear wheels via an efficient shaft drive system. The system is unique and quite reliable and operates quickly ensure rapid direction changing.
http://www.dansdata.com/images/qrc/qrctrans320.JPG
willashcroft 01-25-2008 11:37 AM
Jesus! that looks rather complicated lol!
pede_187 01-25-2008 12:41 PM
The savage doesn't have reverse. He made it like that.
Kemo 01-25-2008 02:41 PM
ORIGINAL: willashcroft
Its a rather simple system, just bulky because you need reverse gears. Main complaints is that its noisy.
new2drifing 01-25-2008 09:48 PM
if i wanted reverse i wouldnt really care about noise. But does that make noice going backwards or when your just going forward?
