RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   wheel wont move!!!! (https://www.rcuniverse.com/forum/redcat-racing-support-427/6964797-wheel-wont-move.html)
dbigfoot111 01-24-2008 09:16 PM
wheel wont move!!!!
i was just trying to fix the dogbone,(i got the rear dogbone out no problem, but i couldnt get the front out i was think get the e clip off, but i decide not to) i got it out i look straight or not, i just hit it a few time put it back and put the wheel on roll it wheel whable take it out try it again same thing happen..so i decide not to fix it any more.
put the dogbone on the wheels on but later when i try to spin the wheels one wheel look like i over screw it and the silver thing wont move it stuck there very very hard
1-now i cant fix my dogbone
2-rear right wheel wont spin(but the rear left spin wiht no reason)i think i over screw the wheels) amd the silver thing go in too far.
well here is the video
http://www.youtube.com/watch?v=UiuBWK-1mfI
please tell me how to fix this and also how to take out the front dogbone(take off to e clip to take off the dogbone? im not sure )
please help me
kuppler 01-24-2008 09:20 PM
RE: wheel wont move!!!!
Well you have the Wheel Hex pushed up to tight on the Wheel Axle. So you need to have a lil gap on it.
im guessing you over tightened the Rim/tire and now it wont move...
well make sure u tighten the wheel hex tight.
twomanytoys 01-24-2008 09:27 PM
Yep looks too tight to me also. Make sure all your bearings are there and shims are there.
ehroof 01-24-2008 09:28 PM
i agree, you too tight, you need to loosen them up a little and leave a little gap.
dbigfoot111 01-24-2008 11:03 PM
do it loose it up by loosen the screw on the stop of the silver thing?
ehroof 01-24-2008 11:08 PM
you loosen the grub screws on the extender
hrdcoreglf 01-24-2008 11:10 PM
loosen the two set screws in the wheel hex and seperate it from the outdrive cup ( the part that holds the dogbone.Then you can see where it is binding.
dbigfoot111 01-25-2008 12:42 AM
ORIGINAL: ehroof
also efroof how do i get the front dogbone out? do take out the e cliper?
dbigfoot111 01-25-2008 12:44 AM
im sorry for my limited understanding,, can u like give me some pic for ex how to take the front dogbone out? al so how do i straighten it out, casue when i taek it out i can barely tell if its bent or not
dbigfoot111 01-25-2008 12:47 AM
there is the clip im not sure if thats the one silver very tiny clip
ehroof 01-25-2008 07:35 AM
same way you took the rear one off, just take the upper arm off at the hub and tilt it forward.
dbigfoot111 01-25-2008 11:32 AM
ORIGINAL: ehroof
but the rear wheel i didnt take off the e clip and i can still take off the dogbone and for the front i rove to shock screw and look like i will have take off the e clip to take the front dogbone out.
well just any budy ever take out there front dogbone wihtout take out the e clip
thankyou
ehroof 01-25-2008 11:34 AM
dont need to take the clip off, just take the screw off the steering knuckle, from the top or bottom and just tilt it so you can get the dogbone out, remove the upper arm.
willashcroft 01-25-2008 11:41 AM
1 Attachment(s)
pinched off macanan from my post but there you are...
dbigfoot111 01-25-2008 11:55 AM
im gonna try this tonight im school right now
thankyou ehroof and everyone
