silly putty
anyone have pics on how to lock your differentals with silly putty. will it make the car wheelie? what does it do with silly putty?
RE: silly putty
you take the diff housing apart, you put the silly putty in the diff with the spyder gears, not the main housing with the pinion and ring gear. what it does is make it a locked posi, this way the 2 wheels grab evently instead of limited slip, will wheelie better with 2 wheels grabbing equally.
RE: silly putty
i would appreciate a pic if anyone has one :D:D
RE: silly putty
It will wheelie better but it won't help cornering. Whwn you corner your diff. lets the outside wheel turn faster than the inside wheel, because the two wheels have different radius. If you lock your diff. your tires will tend to slide around corners.
RE: silly putty
lol. i gess this would be good when i put drifting tires on. ill give it a try.
RE: silly putty
1 Attachment(s)
ORIGINAL: ldgasp i would appreciate a pic if anyone has one :D:D |
RE: silly putty
Ha, sweet pic macanan. :P
RE: silly putty
will a stock car wheelie unassisted?
RE: silly putty
depends on what kind of car you have
RE: silly putty
Do i just throw the silly putty in their whith the grease and all? How much should i use?
| All times are GMT -8. The time now is 11:20 PM. |
