Try again
(SH. 28) Avalanche:
So I got a new clutchbell assembly and new ofna aluminum shoes. After I put it all back together, the clutchbell spins freely but can slide about 3/32" outward. Here is how it goes together from crankshaft end: screw, lock washer, med. washer, 2 shims, spacer shaft that goes around screw, clutchbell, inner bearing, aluminum spacer, outer bearing. This same condition also occued the last time I had to replace it all with the factory parts (and that lasted only a single tank). I dont think the clutch bell should move that much but maybe I am wrong. Any input appreciated. |
RE: Try again
The bell should be shimmed to where it has very little movement front to back, but should spin freely [&o]
RE: Try again
So if I have only three shims on there, and thats all I have, could I use a washer?
RE: Try again
I used a washer in my 18 when I went to the upgraded clutch. Had about the same play befor, 1 washer and bingo!
RE: Try again
Well I just found another shim and put that on there and now there is hardly any play maybe about 1mm. Hopefully it holds up this time!![:o]
RE: Try again
sounds good to me cheeba :)
| All times are GMT -8. The time now is 01:35 PM. |
